2014 Chevrolet Impala
Includes: Bel-air
Platform: B-body & W-body
2001 Impala radiator problems
Old Nov 20, 2018 | 2:33 PM
Dennis211's Avatar
Default 2001 Impala radiator problems
underside of radiator on 2001 Impala
Hi,
Have a 2001 Impala and need help identifying the valve in the picture. The picture is the underside of the radiator.
Thanks in advance for the help!
Old Nov 27, 2018 | 5:24 PM
Frank3's Avatar
Hello Dennis211, welcome to the forum. I don't believe that is a valve in the picture. I believe it is simply the lower rubber mount on the radiator. If I remember correctly there is a hard plastic leg that is molded as part of the tanks on each end of the radiator and a doughnut shaped rubber vibration mount goes around it and is placed in the hole in the radiator core support. It looks like to have a coolant leak somewhere, maybe a bad hose, loose clamp, crack in the radiator tank or corroded tube(s) in the radiator core. When I had a 2001 Impala, I had to replace my radiator when the core started to leak due to corrosion.
