2014 Chevrolet Impala
Includes: Bel-air
Platform: B-body & W-body
2004 Chevy Impala
Old Apr 22, 2014 | 9:10 AM
missys40's Avatar
Default 2004 Chevy Impala
My daughter just bought her first car. Problem when driving down the road battery light comes on, rpm's go up and down and car shuts off! Where she bought it replaced starter switch cause it was loose. But that did not fix the problem, replaced the battery did not fix the problem. Please help
Old Apr 22, 2014 | 12:00 PM
sledge.impy's Avatar
Does it start right back up and idle fine?
Or does it need to cool off?
Any engine codes? What is the battery voltage read? What does it read under load.
Old Apr 23, 2014 | 1:13 PM
missys40's Avatar
Yes starts up and idles fine. Have to get back to you about voltage of battery
Old Apr 23, 2014 | 1:15 PM
missys40's Avatar
On Saturday they plan on changing cam shaft and crank shaft sensor, will this help??
Old Apr 30, 2014 | 7:49 PM
Did it work?
Old Dec 1, 2014 | 2:51 PM
stephpatterelli's Avatar
Default Vacuum hose help!
Im not sure how to post my own post on here so I decided to reply to a forum and hopefully get a reply. I found a broken vacuum hose on my 2004 Chevy Impala LS and I am trying to figure out the name of the hose and part number so I can call dealerships and get a price on the part. the hose is outlined in red in the picture.
Old Dec 1, 2014 | 8:55 PM
Frank3's Avatar
I think I replaced the same hose on my 2001 Impala. I tried to find the actual name and part number in my files but no luck. If I remember correctly it was listed under a canister purge line for the fuel evap system.
ssbm93
Nov 18, 2014 12:26 PM
mrhaney
May 10, 2009 10:05 AM
musicman
Jan 23, 2009 3:31 PM
Chris M
Dec 1, 2008 2:12 PM
