2014 Chevrolet Impala
Includes: Bel-air
Platform: B-body & W-body
2005 Impala 3.4L
Old Sep 11, 2020 | 8:25 AM
plumbbob's Avatar
Default 2005 Impala 3.4L
My car starts fine first thing. I drive for about 5 to 10 minutes shut it off wait a few minutes and it hard starts or not at all. Then I can get it started and it runs fine after that. I've thrown parts at it on both sides. Fuel and spark. I need options at this point. I've replaced cam, both crank sensors temp sensor checked coils injectors.
Old Sep 12, 2020 | 11:16 AM
Impala-Blue-2.'s Avatar
Have you changed the EVAP (Canister) Purge Solenoid ? If bad, it will cause all the problems you are having.
Old Sep 12, 2020 | 2:26 PM
stuck open purge would cause a hard start after refueling.
I would check for a fuel pressure leaking down. pull the vacuum line of the fpr and see if fuel is present.
Old Sep 12, 2020 | 3:23 PM
plumbbob's Avatar
Thank you, but we checked fuel pressure and replaced the fuel pump and the pressure does not leak down.Do you have other suggestions?
Old Sep 12, 2020 | 3:39 PM
plumbbob's Avatar
I've tried most of the things that seemed obvious and I'll give that a try thank you and I'll let you know
Old Sep 19, 2020 | 12:26 PM
plumbbob's Avatar
I put the new evap sensor on and that didn't change a thing. What else could it be that we haven't tried yet. It's funny that after the first hard start it acts fine.
b004508
Jul 2, 2020 5:43 PM
IMAFORDGUY
Mar 6, 2015 3:00 PM
jnde4
Apr 24, 2010 4:16 PM
Leahs05impala21
Apr 6, 2007 1:56 PM
supaangusman
Feb 17, 2007 10:34 AM
