2014 Chevrolet Impala
Includes: Bel-air
Platform: B-body & W-body
2006 Impala "Low Oil Pressure-Shut off engine"
Old August 17th, 2012 | 10:19 PM
06ImpalaDriver's Avatar
Default 2006 Impala "Low Oil Pressure-Shut off engine"
2006 Impala 3.5L (N) with 91K. Msg: "Low Oil Pressure-Shut off engine" and audible warning (chime) comes on, but only after driving about 10 miles. Msg stays on only for a second or two, then goes off. This happens intermittently, but only after driving about 10 miles. I've changed the Oil Pressure Switch with a Delco part. When it started, I had 5,000 miles on Mobil-1 synthetic 5w30. I 've since changed the oil/filter with Mobil-1 5w30 and a Delco filter PF61. I changed the Oil-Pan gasket 5,000 miles ago and saw the pick-up screen in the pan. It was normal and the inside of the pan was clean and debris-free. I'm beginning to suspect a faulty GMLAN. Any Ideas?
JohnnyGeeWhiz (December 26th, 2023)
Old July 1st, 2013 | 7:40 PM
holleydl's Avatar
Default Oil Pressure Low, Shut Off Engine Dash Light
I am beginning to have this same problem. Occasionally, the light comes on, sometimes the bell sounds with it. Always, I shut down, check oil level and color, "all fine", restart, and "poof", it's gone...
Third time in a week. There is no "fault code" stored...
What did you end up doing to resolve? Going a little nuts on this one.
Old July 6th, 2013 | 3:22 PM
The problem is a faulty Oil Pressure Switch. I replaced w/Delco (last August/Sept) and it came back after about 6 weeks. I replaced that part under warranty and got about 6 months before it happened again. This time I used an Autozone switch. It has not happened in the 2 months since I put on the AZ part. Put the car up on ramps/remove starter but leave wired/replace switch w/21 or 22 mm (can't remember) deep socket. Cover starter with plastic grocery bag BC some oil will drip down. Incidentally, I use synthetic oil and change oil/filter at about 6-8 month intervals. Good luck
Old July 8th, 2013 | 1:49 PM
holleydl's Avatar
Default Oil Pressure fake fault
Thanks for the info. I'll try it. The pressure fault came on all weekend and is beyond stressfull. I'll post again after some drive time. I really appreciate the advice.
Old April 7th, 2014 | 5:27 PM
Katcountry54's Avatar
Default low oil pressure light and chime comes on off and on
I have a 06 Impala, it has 164000 miles on it. The "Engine oil pressure low stop engine" light and bell has started coming on. I pull over and shut it off. I can start it right back and it will stay off most of the time. I drove about 20 miles today, and it came on, but on the way back it stayed off. This has happened i think 3 times in the last few months. My oil is full, and will need changed before long, but doesn't look bad. I just got layed off my job, so can't really afford a mechanic, but i don't want to hurt my car either. Can auto zone tell if it is a sensor or not? Really panicked here. Please help if you can.
Old April 7th, 2014 | 10:54 PM
sledge.impy's Avatar
AutoZone probably can not tell you if it is the sensor or not. How would they know? They can sell you one to put on the car.
When was your last oil change? what oil are you using?
164,000 miles is a lot.
My old 2.8 mpfi had bearing issues and I had to use heavier oils.
dbanks17
July 9th, 2015 2:05 PM
James Eagle
October 27th, 2014 2:16 PM
not_a_car_dude
September 15th, 2013 8:41 PM
MikeShirk
December 31st, 2012 11:39 AM
larry_chip
April 24th, 2007 12:46 PM
