2014 Chevrolet Impala
Includes: Bel-air
Platform: B-body & W-body
2006 Impala LT Stereo problem
Old Jan 8, 2010 | 1:17 PM
bruce.t.mann's Avatar
Default 2006 Impala LT Stereo problem
I have a 2006 Impala LT with factory stereo (non-Bose) that's acting bizarre. By that I mean, some days the left front speaker doesn't work, (the chimes can barely be heard), some days the speaker works and the chimes are loud. ?? It's not a loose speaker wire as I've checked with an Ohm meter. Could it be the Body Control Module?
Old Jan 10, 2010 | 10:58 AM
DavidS1206's Avatar
Hello...
Sounds like you have loose connections, or the pins in the connectors on the back of the radio are misaligned. Try removing the radio unit from the dash, unplugging all the connectors from the back, waiting 2 or 3 minutes, then reconnecting everything. Make sure that when you reconnect everything, that the connectors are firmly attached to the radio.
Let me know if this works. BTW, is this the original radio or a replacement? If it is a replacement, you will need a Tech-2 tool to flash the vehicle's vin number into the radio, for it to work properly.
Old Jan 11, 2010 | 9:35 AM
Thanks for the reply. The stereo is original, factory installed. I'll pull the unit, recheck all the wires with an Ohm meter and check the pin connectors.
Old Aug 20, 2012 | 6:18 PM
ChevyImpala2006's Avatar
Default 2006 impala lt
Im having the same exact problem... I've tried everything and it still doesn't work. They aren't working as of now and its been 4 months. No loose connections in site. I've taken the door panels off, taken the radio out and still nothing. I'm thinking about just buying brand new speakers all around and getting a professional to install them. Any other ideas before I sink $$$ into it?
Moutalib
Dec 20, 2023 10:22 AM
davet
Feb 17, 2022 8:08 PM
SVT
Sonic (Aveo)
Jan 27, 2011 6:02 PM
Otown
Sep 20, 2010 3:10 PM
sp3edr4cer
May 10, 2006 6:59 AM
