2014 Chevrolet Impala
Includes: Bel-air
Platform: B-body & W-body
2006 Impala Shaky front brakes
Old Jun 17, 2010 | 4:49 PM
ronanberry's Avatar
Default 2006 Impala Shaky front brakes
Hi. I have a 2006 Impala with a 3.9 engine. I've put 40,000 miles on it in 3 years or so. I've replaced the front disks and pads 3 times due to the steering wheel shaking on medium braking - after they heat up a little. I've had to replace them every 15 or 16 thousand miles. In the past I've taken it to the dealer or Midas and let them put on what they put on.
I want to purchase really good aftermarket front disks and pads that will last. Something better than what I actually need.
I drive mostly on the Taconic Parkway in New York. It's a very hilly and curvy road. This parkway is like a state trooper convention so I don't even speed that much.
Times are tight but I can probably spend up to $350 for the parts if necessary.
Any suggestions are greatly appreciated. I have no idea what to buy.
It's probably a lot to ask but I would prefer something American made..
Thanks
Old Jun 20, 2010 | 5:16 PM
Gwampa's Avatar
Stainless Steel Brake Rotors and those oriental pads that MDTahoe likes so well is what I'd spend $350 on. Any other ideas? By the way, my 06 does the same thing.
Old Jul 28, 2010 | 2:36 PM
my 07 impally's Avatar
My 07 also does this and it is very annoying.. First car i have had do this since my old 73 olds. So whats the answer to fix this? And what about the rear brakes?
Old Aug 1, 2010 | 12:47 PM
osbornk's Avatar
If you've warped three sets of rotors in 40,000 miles, you might need to change you braking habits. I changed out he rotors and installed ceramic pads on mine last week. Took me less than an hour (4 bolts and 1 screw on each side) and I spent just over $100 to make my brakes nice and smooth again after 63,000 miles.
http://cgi.ebay.com/ebaymotors/ws/eB...d=532781550008
http://cgi.ebay.com/ebaymotors/ws/eB...d=532780964008
Old Aug 11, 2010 | 8:51 PM
mjpmin's Avatar
I bought an 08 Impala earlier this year and the warping of the rotors started this summer. I replaced the front rotors with higher quality rotors and pro ceramic pads for around $160. I buy my parts at Rockauto.com.
I think the OEM rotors are junk and a lot of shops replace the OEM rotors with junk and charge premium prices. A DIY brake job on the Impala is pretty easy to do and you save a lot of money.
Mike
Old Oct 3, 2010 | 6:15 AM
yanni2112's Avatar
Changed to drilled and slotted rotors to reduce the heat build up. It worked! I was also tired of getting 15,000 miles and warped rotors
Old Oct 3, 2010 | 9:00 AM
Gwampa's Avatar
My 06 shaking in the front end during braking turned out to be a bad right front wheel bearing (and damn that was expensive $$$). Lightly turned all 4 rotors and installed ceramic pads, Bingo! Now it stops like it should have all along. Go figure.
shanetl1
Apr 10, 2015 5:58 PM
traderyoda
Feb 15, 2013 8:34 AM
Mille Racer 69
Dec 8, 2010 8:26 PM
07SSport
Sep 22, 2009 8:29 AM
