2014 Chevrolet Impala
Includes: Bel-air
Platform: B-body & W-body
2006 Impala SS 3rd and 4th gear slipping
Old Feb 3, 2018 | 5:41 PM
RichC's Avatar
Default 2006 Impala SS 3rd and 4th gear slipping
I have a 2006 Impala SS. In 4th gear especially and some in 3rd gear I am getting a shudder/slip feeling. Definitely at 70-80 mph. Could that be the shift solenoid? I changed the other solenoids last year, but not 3-4. What about the torque converter not locking up since this isn't while shifting.
Old Feb 4, 2018 | 9:59 AM
try gmt nation or transmission bench.com
Old Feb 15, 2018 | 6:50 PM
crawdad's Avatar
Hi RichC, sorry I can't offer help but was wondering if you replaced the solenoids yourself. I just did the Trans Go kit which helped a lot but I may have to do solenoids at some point. Do you have a lot of experience and was it very difficult? I've got a 2003 so should be somewhat similar. Thanks.
Old Feb 15, 2018 | 8:52 PM
RichC's Avatar
I did the solenoids myself. I don't have much experience in transmissions. I do pretty much everything else though. There are some youtube videos that will walk you through changing those solenoids. It's not too difficult.
Old Feb 16, 2018 | 10:50 AM
crawdad's Avatar
Ok, thanks. I watched the video by mph. Probably most concerned with disconnecting the steering. Looks tight in there. I suppose I should disconnect the rack instead. I've got 280K on this transmission so can't be sure if new solenoids will help. Good luck with yours.
Old Feb 16, 2018 | 8:58 PM
RichC's Avatar
The steering is probably the hardest part.
RichC's Avatar
280K? Wow
