2014 Chevrolet Impala
Includes: Bel-air
Platform: B-body & W-body
2008 Impala - False OBD II codes
Old Feb 23, 2019 | 2:40 PM
stahovec@sbcglobal.net's Avatar
Angry 2008 Impala - False OBD II codes
Hello all, anyone have a issue with trouble codes and warnings being displayed on a 2008 Impala but they really don't exist? I get a low oil press. warning, Engine Hot, shut AC off, etc.
But none are true! The low oil press switch was replaced. still get the code. I even disconnected the wire harness from the oil press switch and the alarm still comes on!
Appreciate the feed back. Thanks
Old Feb 23, 2019 | 4:57 PM
Impala-Blue-2.'s Avatar
Why ignore the what the code says it is. Could is be that you actually have Low Oil Pressure ? You need to test by attaching a Oil Pressure Gauge to the port where the Oil Pressure Sensor goes.
Old Feb 23, 2019 | 10:27 PM
I will try a pressure gauge. But the car has been running like this since mid summer. If there was no oil pressure, or low oil Press, I think I would have begun
to see some issues or knocking!
Plus, these codes are all happing at the same time. But I will hook up a gauge and see what happens. Thank you.
