2010 Impala - high speed front end vibration
At speeds above 65, and especially around 75 (no comments please
) there is a slight wobble-type vibration detectable in the steering wheel. It varies with load. On a level, flat road it's almost unnoticeable. Climbing a grade or a curve in the road make it more noticeable, as do wide downhill curves. It's also more noticeable if car is heavily loaded - trunk full, back seat packed.
Car has New Michelins, full alignment, and has been re-balanced 3 times. A visual front end inspection by garage shows NO problems.
Any ideas?
) there is a slight wobble-type vibration detectable in the steering wheel. It varies with load. On a level, flat road it's almost unnoticeable. Climbing a grade or a curve in the road make it more noticeable, as do wide downhill curves. It's also more noticeable if car is heavily loaded - trunk full, back seat packed.Car has New Michelins, full alignment, and has been re-balanced 3 times. A visual front end inspection by garage shows NO problems.
Any ideas?
greatwhite99
Aug 27, 2011 4:00 PM
