2014 Chevrolet Impala
Includes: Bel-air
Platform: B-body & W-body
2013 Impala LT transmission issues
Old Jan 17, 2020 | 4:22 PM
204copper's Avatar
Default 2013 Impala LT transmission issues
So I don't know if I've seen anything posted like this, but I figure maybe it's worth a shot. I was hoping it was a CV shaft, but I don't believe it is. The issue is that when you let off the gas, mostly in town driving, I hear a clunk if you will. Then when you pick up the gas you'll hear it again. It reminds me of slack in a differential and it makes contact on the deceleration and acceleration. If that makes sense? It sounds like it's coming from the passenger side. I jacked it up today and it seems as the slack is inside the transmission, as I saw or felt no slack in the shaft itself. I guess I should see if I can locate a print/schematic for the trans to see what's inside that could be an issue. I'm afraid I'm going to break something!
I also get what feels like a hesitation. Almost like it's missing, but no check engine light, so I assume it's not. I really only notice it when I start up a hill or grade, but if it kicks down it goes away. I'm not sure but was thinking like a lockup solenoid or something, but possibly a pressure related thing since it seems they have some pressure module issues or something like that. I'll have to read up more on that I guess. Maybe I'll answer my own questions lol
anyhow thanks for listening
Old Jan 17, 2020 | 9:23 PM
Frank3's Avatar
Hi 204copper, welcome to the forum. I had a clunk like you describe in my 2001 Impala. It drove me nuts in finding it. I eventually stumbled on it and it turned out to be a bad motor mount. How are your's looking? On the stumbling on a load up a hill, that same Impala had the same problem. I first changed my fuel filter, which did not solve it, then someone suggested checking the fuel pressure regulator. I went through the service manual I have and put a pressure gauge on the fuel rail, sure enough it was low. I also had a bad fuel pressure regulator on my 2002 Tahoe.
Old Jan 18, 2020 | 1:42 PM
204copper's Avatar
I haven't gotten a chance to look at all of them, but if you rev up the motor in park I get no real movement. I'm gonna look harder at it tomorrow though. I can't do the fuel filter as it's in the tank and only comes on the pump apparently. Another brilliant idea from chevy, but better than none at all!
08_Impala
Aug 17, 2019 1:01 PM
Anthony Womack
Jan 7, 2017 2:11 PM
3800Impala
Oct 16, 2015 7:04 PM
Uncle_Charlie
Mar 29, 2014 4:51 PM
BlaneR
Sep 14, 2013 8:17 PM
