2014 Chevrolet Impala
Includes: Bel-air
Platform: B-body & W-body
2014 impala limited ls front hub torque spec?
Old Nov 1, 2021 | 11:46 AM
Ytrsix's Avatar
Default 2014 impala limited ls front hub torque spec?
Can anyone lookup or provide the torque spec for my front hub axle nut. I've seen different figures online. May have changed but mine is 2014 limited ls Thank you!
Old Nov 1, 2021 | 1:23 PM
111 ft/lbs....loosen 45*...tighten to 184ft/lbs
Old Nov 1, 2021 | 2:24 PM
Ytrsix's Avatar
Default Thanks
Appreciate the response! Thank you
Old Nov 1, 2021 | 5:01 PM
Ytrsix's Avatar
Default Precision bearing tech support called
I had called Precision bearing tech support early this morning they just called back. He said 155 then if you hear any noise back off then torque to 165.
Old Nov 2, 2021 | 10:52 AM
my info was from identifix service info.
if you hear noise....its to late the bearing is ****ed
Old Nov 6, 2021 | 8:51 PM
maddog0324's Avatar
Tighten directly to 155 ft-lbs without backing off or re-torque to spec.
RickInKy
Feb 27, 2022 3:50 PM
sledge.impy
Jun 27, 2014 7:02 PM
sledge.impy
Jun 2, 2014 10:51 PM
RickInKy
Mar 14, 2014 8:00 PM
sledge.impy
Jan 21, 2014 8:43 PM
