2014 Chevrolet Impala
Includes: Bel-air
Platform: B-body & W-body
2014 Impala Limited Lt
Old Apr 15, 2025 | 2:13 PM
Helgrind's Avatar
Default 2014 Impala Limited Lt
Stablitrack and abs issues causing the brake light to come on. I have no clue what part to even check to look for to fix it anyone know where I need to look?
Old Apr 20, 2025 | 8:55 PM
maddog0324's Avatar
You need to have the car read with a code scanner, not reader, to get the diagnostic trouble codes. That would be your first step.
Old Apr 20, 2025 | 9:01 PM
Helgrind's Avatar
The only code it pulls up on a diagnostic scanner is multiple random customer cylinder misfire and faulted tire inflation sensors.
Old May 27, 2025 | 8:59 PM
maddog0324's Avatar
Post a picture of your cluster when the engine is running.
Old Aug 20, 2025 | 4:35 PM
Papabuckets's Avatar
Default Possible wheel speed sensor
Mine did the same when both went bad. If I turned sharp left or right and would make a rrrrrr noise and have a split second delay.
bumperking
Feb 4, 2015 1:05 PM
sledge.impy
Jun 27, 2014 7:02 PM
martinsoria_02
Jun 16, 2014 7:59 PM
sledge.impy
Jun 2, 2014 10:51 PM
sledge.impy
Jan 21, 2014 8:43 PM
