2019 Impala LT 2.5L DRL system
While back my driver side headlight went out and found it to not be the bulb. Some friends helped out to find it wasn’t getting power. Then a couple days later my DRL lights went out in the assembly. Again found no power at assembly plug. Now the turn signal doesn’t work on the driver side and fog lamps are intermittent. Is there a module for the headlights? Replaced all plugs in both assemblies as well as entire wire harness to this systems as well as turn signal/headlight control switch on steering column.
Rico NH3llz
March 17th, 2020 11:55 PM
Michal B
October 25th, 2019 10:28 AM
