2014 Chevrolet Impala
Includes: Bel-air
Platform: B-body & W-body
2019 Impala LT 2.5L DRL system
Old Aug 14, 2022 | 1:22 PM
Bradchm's Avatar
Default 2019 Impala LT 2.5L DRL system
While back my driver side headlight went out and found it to not be the bulb. Some friends helped out to find it wasn’t getting power. Then a couple days later my DRL lights went out in the assembly. Again found no power at assembly plug. Now the turn signal doesn’t work on the driver side and fog lamps are intermittent. Is there a module for the headlights? Replaced all plugs in both assemblies as well as entire wire harness to this systems as well as turn signal/headlight control switch on steering column.
tmacharters
Trax
Jan 10, 2022 10:13 AM
Rico NH3llz
Mar 17, 2020 11:55 PM
Michal B
Oct 25, 2019 10:28 AM
kwpsolo
Feb 11, 2009 9:48 PM
