3spd to 4spd conversion
hello again, I have a 63 Biscayne/Impala with a 3 spd on the "tree" transmission. what is involved in converting this to a 4spd on the floor manual shift? and what transmissions are compatable?
RE: 3spd to 4spd conversion
the swap is pretty easy since your car is already a manual trany'd car. u could use a B.W. T-10 from the Camaro's, but if u r going through the trouble to upgrade your "3-on-the-tree", why not go 2 a 5 spd. and benifit from an o.d.? u can then run higher gears, get better acceleration, and still benifit from reduced highway RPM's. u will probably need 2 relocate/fabricate the cross member, shorten the driveshaft, speedo cable length probably won't match, and u need 2 cut the floor of course. if u r looking @ getting a newer trany w/o.d. and want a hydraulic clutch, look towards the Street Rodder's, they've got all kinds of neat $hit for type of thing. IMO, getting the clutch situation resolved & working smoothly is probably the biggest headache u'll have (& not that big of one either). good luck
racedodge
April 22nd, 2008 9:31 PM
rcbigblock
March 21st, 2006 12:16 PM
rcbigblock
March 16th, 2006 8:52 AM
