Awkward noise in engine bay
2015 Chevy impala
4dr 3.6 v6
Hi, I've noticed recently that there is a weird noise that sounds like it's coming from the engine bay, but im not positive on the location. It sounds like a rattling or almost a chain rubbing against something. When I hold on the brakes at a red light for example, it will make the noise. Also, I can hear it at times when the engine idles, but only below about 2k rpms. Any help on this matter would be greatly appreciated!!!
4dr 3.6 v6
2015 Chevy impala
4dr 3.6 v6
4dr 3.6 v6
Chevrolet Impala 3.6 liter sedan:
Problem: A driver may report that a growling noise is coming from the front of the vehicle.
Cause: The condition may be caused by a loss of pre-load on the front-wheel bearings due to the axle nut.
Correction: To diagnose the noise, re-torque the existing front axle shaft nut to 162 ft/lbs and test drive the vehicle. If the noise is eliminated, replace both front axle nuts with the updated part (P/N: 10257766). On vehicles equipped with the police package, add an additional Nord-Lock.
I hope that helps you, Cgreen. I believe that you can rent a torque wrench at lots of auto part stores, so you won't need to buy one, just for a one-time use. I'd use Locktight on them, as well.
I believe I found out the source of your issue, after quite a bit of searching, as it was quite intriguing to me. This is what I found out about your 2015
Update, I re-torqued both axle nuts then took it for a test drive, but the sound is still there but quieter. It also sounds like a groan when I slowly release the brake pedal like a caliper is grinding.
jamesdanielsone@gmail.com
Sep 19, 2016 5:27 PM
rervf23
Aug 14, 2011 11:30 AM
