2014 Chevrolet Impala
Includes: Bel-air
Platform: B-body & W-body
Awkward noise in engine bay
Old May 15, 2021 | 4:32 PM
Cgreen's Avatar
Default Awkward noise in engine bay
2015 Chevy impala
4dr 3.6 v6
Hi, I've noticed recently that there is a weird noise that sounds like it's coming from the engine bay, but im not positive on the location. It sounds like a rattling or almost a chain rubbing against something. When I hold on the brakes at a red light for example, it will make the noise. Also, I can hear it at times when the engine idles, but only below about 2k rpms. Any help on this matter would be greatly appreciated!!!
Old May 15, 2021 | 11:11 PM
oilcanhenry's Avatar
Originally Posted by Cgreen
2015 Chevy impala
4dr 3.6 v6
If you put it in neutral, does it still make the same noise?
Old May 16, 2021 | 5:23 AM
Cgreen's Avatar
It doesn't make the noise in neutral, so I'm also wondering if it has to do with the driveshaft
Old May 16, 2021 | 9:28 AM
I believe I found out the source of your issue, after quite a bit of searching, as it was quite intriguing to me. This is what I found out about your 2015
Chevrolet Impala 3.6 liter sedan:
Problem: A driver may report that a growling noise is coming from the front of the vehicle.
Cause: The condition may be caused by a loss of pre-load on the front-wheel bearings due to the axle nut.
Correction: To diagnose the noise, re-torque the existing front axle shaft nut to 162 ft/lbs and test drive the vehicle. If the noise is eliminated, replace both front axle nuts with the updated part (P/N: 10257766). On vehicles equipped with the police package, add an additional Nord-Lock.
I hope that helps you, Cgreen. I believe that you can rent a torque wrench at lots of auto part stores, so you won't need to buy one, just for a one-time use. I'd use Locktight on them, as well.
Old May 16, 2021 | 10:55 AM
Cgreen's Avatar
I will try this when I get out of work,, I greatly appreciate the help and will be sure to give you an update!
Old May 16, 2021 | 11:50 AM
Please do so. I am very interested in the results, and I hope this solves your issue.
Old May 17, 2021 | 1:42 PM
Cgreen's Avatar
Update, I re-torqued both axle nuts then took it for a test drive, but the sound is still there but quieter. It also sounds like a groan when I slowly release the brake pedal like a caliper is grinding.
jamesdanielsone@gmail.com
Sep 19, 2016 5:27 PM
Jeffprenger
Apr 28, 2016 7:29 AM
rervf23
Aug 14, 2011 11:30 AM
TRProffitt
Jan 10, 2009 9:16 PM
bbtahoe
Sep 27, 2006 1:35 PM
