2014 Chevrolet Impala
Includes: Bel-air
Platform: B-body & W-body
blinkers
Old Dec 23, 2008 | 5:14 PM
biga9905's Avatar
Default blinkers
having problems with rear blinkers and brake lights. first the driver side stopped working now a few months later passenger side stopped. front blinkers still work. wtf is going on
Old Dec 24, 2008 | 11:54 AM
shawnvw's Avatar
Banned
Default RE: blinkers
probably burnt out bulbs
Old Dec 24, 2008 | 2:02 PM
biga9905's Avatar
bulbs are both fine. fuses are fine also.
Old Dec 28, 2008 | 6:18 PM
shawnvw's Avatar
Banned
check for proper ground at the socket as well as corrosion in there
Old Dec 28, 2008 | 9:00 PM
mightydog4805's Avatar
also check to make sure the bulbs havent melted anything in the light fixture. Ive heard of ppl using aftermarket lights and it isnt the right voltage and ends up melting vital parts of the light fixture..just an idea
Old Dec 29, 2008 | 12:50 PM
budsjlm's Avatar
id have to say go with checking the grounds thats always a good spot to start if bulns are good and nothings melted check the ground had a head light in my 89 blazer that was dim and would get bright as the blinker turned on and off riped apart the hole front end but found it right up front where i dint need to pull a part anything
mikedx
Jan 23, 2008 11:54 AM
captains
Nov 20, 2007 9:12 PM
mlg
May 21, 2007 9:13 AM
IRready
Sep 21, 2006 12:48 PM
Omnious
Jun 11, 2006 11:43 AM
