2014 Chevrolet Impala
Includes: Bel-air
Platform: B-body & W-body
a/c compressor not engaging
Old Jul 9, 2011 | 1:59 PM
JLAimpala's Avatar
Default a/c compressor not engaging
I checked the fuses and swithed the horn relay with the a/c compressor relay (same partl). The horn still works and the compressor still doesn't.
Anybody know what to check next? Thanks
Old Sep 7, 2011 | 6:46 PM
carl2591's Avatar
put pressure gauges on and make sure you have enough gas to allow compress to run. gas to low will not run. its a safety. most lilky need to be above 25 PSI static.
Old Sep 8, 2011 | 2:16 PM
osbornk's Avatar
low on freon.
Old Sep 8, 2011 | 3:10 PM
kevinkpk's Avatar
There is a low cut off switch in the system. If you have a voltmeter, unhook the plug to the clutch with the a/c turned on, if you have 12 volts, go from there.
JLAimpala
Jul 9, 2011 4:20 PM
radetic
Cobalt
Jul 7, 2011 3:50 PM
BYUFanatic
Aug 2, 2008 1:30 PM
holyspatulaboy
Feb 20, 2008 5:26 PM
timdogg1313
Sep 9, 2006 7:01 PM
