2014 Chevrolet Impala
Includes: Bel-air
Platform: B-body & W-body
camshaft position (cmp) actuator solenoid control circuit
Old Dec 13, 2015 | 7:15 PM
Jerrod Tynes's Avatar
Default camshaft position (cmp) actuator solenoid control circuit
My wire got shredded in the engine and I want to just add a wire on ends to simply reconnect the 2 ends but what if any type of wire is available or can I just use any type of automotive electric wire? It's a 2006 ls model with the 3.5 flex fuel if that matters...
Old Dec 14, 2015 | 8:12 PM
chevy55's Avatar
just get a piece of wire about the same size that your oem wire is and you should be good to go.
Old Jan 14, 2016 | 12:31 PM
I'm still having that same problem after soldering it together no grounding through the wires but thanks for the input
