2014 Chevrolet Impala
Includes: Bel-air
Platform: B-body & W-body
Cruise Control Concern
Old Oct 11, 2007 | 2:41 PM
Firewireman's Avatar
Default Cruise Control Concern
I just bought a 2006 LT3 with 33k on it. I just noticed the cruise control does something funny when going down a hill or coasting and the engine doesn't have to work to keep up to speed. The tachometer jumps up and down by about 200-300 RPM and the car kind of jerks front to back until the ground levels out again and then the RPMs are steady. Anyone ever had this? It's still certified so I may take it back to the dealer to check it out.
Old Oct 11, 2007 | 4:19 PM
rbarrios's Avatar
Default RE: Cruise Control Concern
next time you think its going to do it- put the car in 3rd. (to take it out of overdrive).
and set cruise and head downhill. see if it does what you say...
Im thinking its going in and out of overdrive thus the jerking and RPM ups and downs
Old Oct 11, 2007 | 7:15 PM
Sounds like a plan, and I think you're right. Is this something that is within spec or should it be smoother than that?
Old Oct 11, 2007 | 8:30 PM
twizzle12's Avatar
my monte carlo also does this no clue on what it might be...
Old Dec 23, 2007 | 10:12 PM
Took it back to the dealer for multiple problems, leaking head gasket, failing power steering pump, and the cruise control issue. They had my car for over two weeks and were not able to replicate the issue. I note it was happening when the weather was warmer, now that it's cold it doesn't do it as much. I'm not sure if it's related to the weather, or maybe replacing the head gaskets did something, not sure.
pcwilcox
Oct 21, 2013 11:00 AM
liljoe66
Aug 5, 2011 12:44 PM
kbridge234
Sep 4, 2008 10:03 AM
smithk3933
May 12, 2008 10:16 AM
Natidonkryda
Mar 19, 2008 12:46 AM
