2014 Chevrolet Impala
Includes: Bel-air
Platform: B-body & W-body
EBCM problems - ABS/Traction Control/BRAKE light illuminated
Old Apr 7, 2016 | 10:14 PM
lylesr3524's Avatar
Default EBCM problems - ABS/Traction Control/BRAKE light illuminated
Hey guys!
I drive a 2009 Chevrolet Impala 2LT with a 3.9L engine with 79k miles.
I've been having issues with my ABS/Traction Control. I first noticed it when I would take off from a dead stop and the ABS/Traction Control would kick in and the brakes would pulse and slow my takeoff.
The Traction Control light would also blink during this short process.
After this started, I replaced both front driver and passenger side hub assemblies. The problem still persisted. I did notice that if I turn off the traction control, the TC would not engage during takeoff.
After the hubs were replaced, I started seeing intermittent ABS and TC warning lights along with the warnings "Service Traction Control, Service Stabilitrak, Service Brake Assist".
I replaced the hubs again, thinking it was a bad set of speeds sensors and the problem still persisted.
The problem got worse. The intermittent warning lights and messages were showing up more often (any turn of the wheel, going over speed bumps).
I finally replaced the Electronic Brake Control Module (EBCM) ordered from gmpartsdirect.com (PN: 25879093, part number was confirmed with a GM dealership and VIN provided to GM Parts Direct).
After replacing the EBCM, the car drives fine. The brakes no longer engage during takeoff, but now the ABS, TC, and BRAKE warning lights are present along with the same messages.
Here are my questions:
Does anybody have any knowledge on this?
Has anybody experienced this and fixed it?
Will the warning lights expire after a certain time/distance or will they need to be cleared with a code reader?
Did I install a bad EBCM?
Thanks in advance for any info provided.
- lylesr3524
