2014 Chevrolet Impala
Includes: Bel-air
Platform: B-body & W-body
Old Jul 24, 2015, 4:25 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Engine and Powertrian
Print Wikipost
Finally a cheap passlock fix!
Old Oct 3, 2010 | 7:30 PM
  #51
officerdave's Avatar
shawn, here is my situation. 2002 Impala with 90,000. Entire key way cylinder replaced, pass lock replaced by dealer. New starter,new alternator,new battery.....cars fires up one day and drives....four or five days later engine TRYS to turn over, u can hear it miss fire in at least one cylinder and then it just cranks and cranks... Let it sit for a while and sometimes it starts up. Repair shop checked fuel pressue, injector operation etc car is getting fuel so I am thinking is a sensor intermittently seeing the car as having a security issue and shutting off the fuel? computer hickup? your thoughts thanks officerdave
Old Oct 6, 2010 | 8:54 PM
  #52
TygerFangs37's Avatar
Originally Posted by jondoe28
Had this done a couple of weeks ago. Hasn't acted up once, security hasn't come on at
all either. Hired our tractor mechanic to do it. Said 2 contacts were burnt on key switch.
Used sand paper to clean them, and good to go. Cut and pasted from another site:
I just fixed my 2002 impala security light issue. It cost me 2 hours, no money. Here is how the system works. The passlock sensor and the ignition switch are in series. When you turn your key you generate a low current read by the body control module. If the current generated is out of range the BCM won't recognize the signal and your car won't start for 10 min. There could be different reasons why the signal is out of range. On most of the cases the ignition switch contacts are burned out, and this will cause a voltage drop on the contact so the signal getting to the BCM is going to be lower than usual so it will be out of range. Take your ignition switch out (if you don't know how send me your e-mail (believe me I'm not looking for e-mail addresses I just need to scan the instructions, since I have them only printed out) and I'll send you detailed instructions for free. Once the switch is out remove the cover on the back of the switch (it is clipped on, all you need is a flat head screwdriver). Once the cover is removed you should see 5 fairly big electric contacts. I bet at least one or two are burned out. Clean them with fine sand paper until their surface is clean and flat and make sure the steel springs pressing the contacts together are tight and are pushing the contacts firmly. If not, using pliers bend them to get good contacts. Reinstall the switch and your car should start every time. If the contacts are really bad you might have to change the ignition switch.
I know dealers want to change every part on the car so please do not let them change the passlock sensor. The passlock sensor is a hall sensor and there is no reason for the sensor to go bad.
Hey, Jondoe28. I would love to have those instructions. I live in DC (not the good part either) and being passlocked out and sitting in my car is definitely a bad idea. It way too dangerous for this **** to keep happening. If you can please send me the instructions to my email address. It's TygerFangs37@hotmail.com. I would definitely appreciate it.
Old Oct 8, 2010 | 1:39 PM
  #53
jondoe28's Avatar
Mike (our mechanic) is coming out to work on a steiger tractor this weekend. I'll ask
him to write down how to dis-assemeble things and such. Mine works beautiful. Usually lasts a year at a time.
Old Oct 10, 2010 | 6:28 PM
  #54
Will do. Can't wait to get those instructions because just today, I've been passlocked out of my car four times in the last hour and a half. All in bad places. This is out of control. Chevy should have recalled this.
Old Oct 19, 2010 | 3:54 PM
  #55
olimartel's Avatar
Default impala passlock
how do you remove the ignition? there is no room!
Old Oct 19, 2010 | 9:09 PM
  #56
olimartel's Avatar
Please send me those diagram : olivier.martel@hotmail.com
Old Oct 19, 2010 | 9:11 PM
  #57
olimartel's Avatar
Originally Posted by mobileinstaller
ok first off changing the ignition switch and tumblers will do absolutely nothing sorry if you have already done this. there are three main components to the passlock II system the passlock sensor, the BCM, and the Ecm and of course the wiring in between. Odds are if this keeps happening and there is no other problems such as door locks freaking out trunk release just goin off then it's not the bcm if you do the relearn feature and it works the it is also not the Ecm. so you are left with the 3 wires that run from the bcm to the passlock sensor.odds are the passlock sensor is bad. now there are two solutions either go to the dealer and have the sensor replaced or bypass the system for good. any respectable mobile electonics installer should be able to do this no problem it takes me about 20 mins and i personally charge 40 dollars to do so hope this helps also if you are mechanically inclined in electronics i can send a diagram on how to bypass it yourself hope this all helps
Please mobileinstaller, send me the bypass diagram. olivier.martel@hotmail.com
Old Nov 1, 2010 | 11:52 AM
  #58
barose's Avatar
Jondoe28
Can you send me a copy of how to get to the ignition switch, if you still have it available
barose@onetel.com
Much appreciated
Brian
Old Nov 1, 2010 | 12:50 PM
  #59
rtron1's Avatar
Default Please send me a copy of the passlock bypass diagram
Please send me a copy of the diagram to tal_12@hotmail.com.
Old Nov 5, 2010 | 10:35 AM
  #60
tinchief123's Avatar
hey jondoe can you send me the instructions on how to take apart my ignition switch and clean the contacts? about how long does the job take? my e mail is : emailchieftain@yahoo.com i have 1999 chevrolet suburban LT K1500n 4wd. thanks again?
