2014 Chevrolet Impala
Includes: Bel-air
Platform: B-body & W-body
Haunted?
Old Nov 1, 2019 | 6:34 PM
Vern31's Avatar
Default Haunted?
We have a 2016 Impala LT that seems to be haunted.
When we start the car after it has been off for a while, either overnight or just while we were shopping, the comfort controls have reset to lower settings.\
The passenger temp control will be down to 60 degrees & the blower speed will be down to low. The drivers' temp. control does not change.
The car was previously a rental car with Enterprise Rentals so someone may have done something to make it do this.
If this is so, how can I cure it from doing this?
Or, is it haunted?
Vern
Old Nov 1, 2019 | 6:52 PM
kevinkpk's Avatar
If you have the owners manual, it should give you instructions on how to set up automatic controls.
Old Nov 1, 2019 | 7:46 PM
oilcanhenry's Avatar
Or, is it haunted?
Vern
Naw, only F**D's are haunted. Could be the A-A-T sensor, but not likely. Sounds like it might be a software issue to me. Something isn't holding steady on your Impala.
Old Nov 1, 2019 | 8:14 PM
Vern31's Avatar
A-A-T?
Vern
Old Nov 2, 2019 | 12:39 AM
A-A-T?
Vern
It's short for Ambient Air Temperature sensor.
Its a very small device mounted ahead of the A/C condenser, usually behind the front grill. It is part of the Climate Control System, but to my knowledge it effects the A/C system much more so, then the heating system, if at all. It's the same device that allows the vehicle to read the outside temperature and display it on the dash panel.
Since your issue is cold temps out of the climate control box, I don't believe it's an issue. If it were, they are $4 or $5 dollars, and easy to replace on most vehicles..
bkldiver
2007 - 2013 (GMT900)
Jul 31, 2017 6:39 PM
greasemonkey47
Jul 15, 2016 9:52 AM
dmahillen
Nov 7, 2013 11:12 AM
hindesketchup
Jun 16, 2009 5:33 AM
