HELP! 08 Impala V6
HELP! 08 Impala V6
I purchased an 2008 Impala with a V6 from Carmax about 6-8 months ago and I've been doing my own oil changes with synthetic oil. (The car currently has about 40,000 miles on it). The issue I'm having is that somehow I've consumed all the oil between oil changes (I'm not due for another oil change for about 1,000 more miles). My car had alerted me that I had a low oil level as I was turning up an on-ramp. When I checked my oil level, it wasn't even registering on my dipstick so I thought I probably had a leak. So I put it up on a rack at my work and discovered no leaks. However, I did notice that my tailpipe is blackened more than what I would consider normal which leads me to believe it's burning the oil. Is this problem common? How do I fix it?
One other thing, if you cannot find where your oil is "going" place a piece of cardboard under the engine when you park it, if you do have a leak, it will show.
Thank you! If it is leaking, it's not making it out of the car. Also, I'm not seeing smoke but the tail pipe is blacker than I imagine it should be. I'm not the most car savvy, but I know the basics. I will check the coolent, but what exactly will I be checking it for? I also had a mechanic friend of mine tell me my piston rings might be bad, is this possible?
Ok, thanks again. I appreciate you sharing your knowledge with me.
