Help a girl out PLEASE
Summary......2002 Impala
upper radiator hose was collapsed. car did not run hot. loss of power on acceleration.
replaced hose. still loss of power. new hose collapsed after car cooled off.
drained and flushed radiator, cleaned reservoir, replace thermostat, and radiator cap. refilled radiator, water is cycling in radiator. still no power. no loss of water or oil. no oil in water, no apparent water in oil. no water in tail pipe.
no problems at idle. when i push it to 4,000 rpms in park the car 'shudders' and continues until i release the accelerator.
when driving...take off is ok, speed picks up until i hit 2,000 rpms, then the car 'sulls' down and if i continue to push it to 3,000 it starts 'spitting and spurting'. stops when i release the accelerator.
when i turn the car off it gives a 'humpf' a few seconds after shutdown.
I would appreciate any input. sorry, i do not explain things very well, so please ask any questions.
I'm at my wits end!!!! PLEASE HELP!!
no idea on the loss of power but the hose collapsing could be the little tube that runs from the radiator neck to the overflow tank could be plugged or maybe a bad radiator cap just a guess... as for it shuttering at 4000 rpm there is a rev limiter that cuts the engine out if you give it alot of gas while it's in park so in other words it's supposed to do that lol
kas22ohio
Oct 28, 2008 9:09 AM
