2014 Chevrolet Impala
Includes: Bel-air
Platform: B-body & W-body
How to remove headlights
Old Apr 3, 2007 | 9:29 AM
Xieon's Avatar
Default How to remove headlights
Hey, I'm installing hideaways in my headlights, and can't figure out how to get the headlight covers off to expose the lights?
Could anyone tell me how to do so?
Old Apr 3, 2007 | 1:26 PM
rbarrios's Avatar
Default RE: How to remove headlights
hideaways?
it should be simple-
there is most likely 2 tabs on top of the headlight assembly. theyre usually white- pull them up- and the entire headlamp assembly can come out- obviously you need to disconnect the wires to the bulbs.... but that should be it. youll need to open the hood
Old Apr 3, 2007 | 10:54 PM
Xieon's Avatar
Thanks, I couldn't figure out how to get the damn things off for the love of me lol, guess its pretty simple.
Hideaways are stobe lights that go into the headlights that way when they flash the headlights relective surface makes them much brighter. Also, you can't see them unless you look straight into the headlight fixture (thus the "hide"-away)
Old Aug 18, 2007 | 1:06 AM
chelle26's Avatar
look for your manuals
Old Aug 23, 2007 | 3:24 PM
jdonline
Guest
Posts: n/a
It's a fairly simple process. Just locate the tabs and disconnect the wiring from the headlamps. Good luck.
JD
deejayrock
Oct 23, 2024 12:23 PM
David_lee1993
Nov 1, 2012 11:06 PM
youmeill
Mar 14, 2012 9:06 PM
fireman526
15
Feb 5, 2008 10:36 PM
Goodwrench29
Apr 25, 2006 9:51 PM
