2014 Chevrolet Impala
Includes: Bel-air
Platform: B-body & W-body
impala fuel pump?
Old Aug 2, 2008 | 8:42 AM
kdm's Avatar
kdm
Default impala fuel pump?
Ok I replaced the fuel pump in my 01 impala back in march the fuel gage was fluctuating. Now it is acting up again it will go all the way to full on start up and 30 secounds later it will go all the way down to empty. So I'm thinking it's the sending unit again. But I want to ask does this problem point to a bad sending unit?
All so how do I remove the back seat to make it easyer to access the fuel pump. I have looked but just cant figure out how to do it. I know I can go through the trunkand I will if I have to, but it,s just pain to get to it that way
Old Aug 2, 2008 | 12:02 PM
kdm's Avatar
kdm
Default RE: impala fuel pump?
Well I found out my problem the float arm broke lose from the pump unit. now just have to have this one switched out and put it back in.
Old Aug 2, 2008 | 6:05 PM
HotSauce6226's Avatar
Impala Super Moderator
Did you drop the tank? if so i gotta better idea
Old Aug 4, 2008 | 10:17 AM
kdm's Avatar
kdm
No I did,t have to drop the tank. This car has a access panel in the trunk. I was able to fish out the float arm. Took the old pump to advance and they replaced it with a new pump. Only thing about the new pump is I had to cut and splice on a new wiring harness.
Old Aug 4, 2008 | 12:48 PM
^^^ Good job. I wanted to make sure you knew that. Great Job
mangomanj
Aug 17, 2014 9:51 PM
BRB
Dec 28, 2012 8:34 PM
hunter10220
May 18, 2011 8:37 PM
