2014 Chevrolet Impala
Includes: Bel-air
Platform: B-body & W-body
Impala signal light problem
Old Aug 10, 2008 | 1:55 PM
chvyno1's Avatar
Default Impala signal light problem
My 2002 Impala signal lights work sometimes and sometimes they don't. I've changed the flasher. The weird thing is that usually if I hit the hazards for a few seconds that then the signal will work. Also, if I turn the turn signal on when's it's not working, the brakes lights stop working. My husband says one shouldn't have anything to do with the other but that's what's happening. He hates to take stuff to the Chevy garage and blow a load of money if it's something maybe we can fix. Anyone have any ideas?
Old Aug 10, 2008 | 6:06 PM
HotSauce6226's Avatar
Impala Super Moderator
Default RE: Impala signal light problem
read the manual and check the lamp fuses you might have one out, or a bad ground
Old Aug 10, 2008 | 7:49 PM
shawnvw's Avatar
Banned
When you say you've changed the flasher you mean you changed the hazard switch right? The only other common point between the signals\hazards\brake lights is the signal switch itself. May want to look into that
Old Sep 11, 2008 | 1:41 AM
chankee's Avatar
Banned
Hopefully that goes the same with chevrolet impala tail light. I've replced them lots of times already but haven't experienced them to be always in good condition.
Old Sep 11, 2008 | 8:25 PM
sean/sean's Avatar
Multi-function switch islikely the problem. but not cheap
fishingpro77
HHR
Aug 4, 2016 12:44 AM
RomanGuzi
Oct 2, 2011 11:40 AM
shepherd564
Aug 29, 2010 3:59 PM
d1nonly34
May 9, 2009 10:21 AM
NoBrakes
Apr 15, 2009 6:14 PM
