No signal from BCM for reverse lights.. and still 3rd brake light problem
Old May 5, 2009 | 7:31 PM
d1nonly34's Avatar
Default No signal from BCM for reverse lights.. and still 3rd brake light problem
OK heres a quick setup of whats going on. Few months ago I did complete interior swap (including dash). I had grey cloth LT1 interior to black LTZ interior. A month after that the BCM went bad from a pinched cable from my aftermarket alarm. The BCM was replaced but after for some reason the third brake light and reverse lights dont work. I have a buddy that is a tech at the dealer but he is extremely busy so I cant run it through warranty. Today I decided to just run a line with a relay to the third brake just to get that out of the way, I was planning on doing the same thing for the reverse lights because i Just installed some reverse sensors and I needed the signal to power it but I am not getting any signal whatsoever from the BCM. Its supposed to be a dark blue wire at the white plug pin 22 at the BCM but I cant understand why. Does anyone have a clue?
Old May 5, 2009 | 11:32 PM
suzuki-guy's Avatar
Sounds like the new bcm is bad did you buy it new?
Old May 6, 2009 | 9:19 AM
d1nonly34's Avatar
Yes it is a new bcm, it was changed at the dealer. Also, before the BCM went bad everything was working just to let you all know.
Old May 6, 2009 | 4:34 PM
suzuki-guy's Avatar
just because its new doesent mean its good if the dealer installed it take it back to them and have it fixed prolly your best bet!
Old May 9, 2009 | 10:21 AM
d1nonly34's Avatar
yeah it must be that, its the only thing I could think of cause Im sure the signal goes to the BCM first instead of anywhere else.
Hectorson3
Sep 13, 2014 12:22 PM
WTH275
Dec 12, 2011 5:26 PM
tokillamurderer
Aug 21, 2011 8:09 PM
foxracing254
Apr 7, 2011 12:12 PM
d1nonly34
Apr 2, 2009 11:14 AM
