2014 Chevrolet Impala
Includes: Bel-air
Platform: B-body & W-body
Impala sunroof 2009 wont close' Schematic'
Old Jul 9, 2014 | 8:32 AM
kats2009's Avatar
Default Impala sunroof 2009 wont close' Schematic'
My wives sunroof wont close so I took the motor out and it will travel the open direction but not the close way.I was wanting to know what might be telling the motor not to turn in the close way or is it the motor but it does travel the opposite direction.This inspection is done with me holding the motor in my hand and disconnected from the worm gear on the cables and by hiitting the close and open buttons. I need a schematic if anyone could help me out on that would be great. Thanks
Old Jul 9, 2014 | 10:35 AM
Frank3's Avatar
I don't have a schematic, but with the door windows the motor is reversed by simply reversing the power to the motor terminals. When you have the motor out and was testing, how was the motor hooked up to power one way then the other? With test leads or the actual wiring from the Impala. If you were using test leads, then possibly the motor and/or internal switches could be bad. If still connected to the Impala wiring harness, you could still have a bad switch.
Old Jul 9, 2014 | 2:49 PM
kats2009's Avatar
I had it still hooked up to the impala and hit the open and close switches for the sunroof it wound rotate one way but not the other.
Old Jul 9, 2014 | 5:56 PM
sledge.impy's Avatar
Then maybe your switch is bad.
If you reversed the power on the motor, like F3 suggested, you could see if the motor worked backwards with your OPEN button.
Probably easier to throw parts at it. Just replace the switch first. Then if that don't work, the motor.
Then if that doesn't work either, then we can find something in between to replace.
Old Jul 10, 2014 | 7:51 AM
kats2009's Avatar
Will reverse the wires on the motor but I did check the resitance on the switch and it was 37 ohms on both forward and reverse so figured it was good. What I am thinking is that something has to tell the motor that it is all the way forward . Thanks
Old Jul 10, 2014 | 10:16 AM
Were you able to close it manually?
Sunroof will not close - Fixya
Chevy Impala SS 2005 sunroof wont open at all - Fixya
2002 Chevy Impala Sun Roof Malfunction: Electrical Problem 2002 ...
2009 Chevrolet Impala Sunroof Parts
Old Jul 10, 2014 | 11:25 AM
kats2009's Avatar
Yes but wont go down.
madhttr
May 18, 2014 1:26 PM
Azn4yah
Sonic (Aveo)
Feb 24, 2014 7:02 PM
Minarets
Jul 25, 2011 9:38 AM
