2014 Chevrolet Impala
Includes: Bel-air
Platform: B-body & W-body
Impala traction control
Old Jun 4, 2018 | 7:36 PM
tyler stache's Avatar
Default Impala traction control
So when I turn left (all the way to lock) in my 2011 impala LT and get going like faster than 5mph it’ll engage traction control and you can feel it because it jerks you... wheel bearings don’t make any noise... both the wheel bearings and or wheel speed sensors are very spendy don’t wanna replace everything and didn’t need to.... wheel bearings don’t make sound or wiggle really at all car drives decent to be honest it’s only when I turn left to lock.... also for my second issue the fan will turn off randomly then if u kick or hit the dash or kick under the dash a time or two it’ll turn the fan back on this is a issue because when it’s like 110F here and I have my dogs they will get super hot thanks guys I’m brand new here!
Old Jun 4, 2018 | 9:29 PM
either you are the Fonz or the brushes in the blower motor fan are worn...hitting it helps the brushes make contact and it starts running....replace the blower motor.
check for codes in the ebcm. a full function scan tool is required to read chassis codes. a code reader will not access these codes.
