2014 Chevrolet Impala
Includes: Bel-air
Platform: B-body & W-body
Key fob and tire pressure sensor wiring
Old Sep 12, 2018 | 1:48 PM
JohnMik's Avatar
Default Key fob and tire pressure sensor wiring
I have 07 police impala and need help finding where these wires go. This is inside the driver side panel. My key fob and the tire pressure sensor does not work so I think this is the issue.
[img]blob:https://chevroletforum.com/cea0de0d-41c8-4134-9df4-574753675b6a[/img]
Old Sep 12, 2018 | 1:50 PM
JohnMik's Avatar
Old Sep 12, 2018 | 6:14 PM
Impala-Blue-2.'s Avatar
None of that wiring looks like GM Factory Wiring, nor do the connectors. That wiring is probably left over from the Police Gear that was removed from the vehicle before it was sold.
Since this was a Police Vehicle, have you checked if it even has TPMS Sensors in the wheels, and if it does, they may be worn out. They have a life of about 7 years in normal use. As for the Key Fob not working, not sure on this, did it ever work for you ? It may have been disabled being that it was a Police Vehicle.
Old Sep 15, 2018 | 7:46 PM
JohnMik's Avatar
Default What does the one harness connect to on the rclda
Ok what so I’ve seen antenna modules that have two connections but mine only has one connection. Is that for the keyless entry and tpms sensor all in one harness? Here’s a picture of mine.
