2014 Chevrolet Impala
Includes: Bel-air
Platform: B-body & W-body
Key wont turn. Brake Pedal to the floor. Stuck in a parking lot !!
Old Feb 24, 2012 | 6:34 PM
BNR34RB26DETT's Avatar
Exclamation Key wont turn. Brake Pedal to the floor. Stuck in a parking lot !!
So as the title says, Im struck in a parking lot
its a 2003 Impala.
I put the key in ignition and the key wont turn at all. not even to electronics position. and car obviously would not start.
Sifter is stuck parking position (Automatic)
Brake pedal is stuck to the floor.
Sealing lights come on.
Has anybody had similar issues like this? Battery is working fine. Could it be a fuse? Im pretty sure its something electrical
Old Feb 24, 2012 | 8:03 PM
Official GM Rep
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> If your key seems stuck in OFF and you can’t turn it, be sure you are using the correct key; if so, is it all the way in? Turn the key only with your hand. Using a tool to force it could break the key or the ignition switch. If none of this works, then your vehicle needs service.
I encourage you to have the vehicle inspected by a certified technician.
Louis
GM Customer Service
Mark_MS
May 16, 2015 1:12 PM
fought1
Nov 3, 2013 11:39 AM
G T Igofast
Sep 3, 2013 3:46 PM
philipjohn52
Aug 13, 2012 1:50 PM
sf112624
Feb 28, 2011 7:55 PM
