2014 Chevrolet Impala
Includes: Bel-air
Platform: B-body & W-body
Looking for turn signal help…
Old Jul 12, 2025 | 5:31 PM
Parks911's Avatar
Default Looking for turn signal help…
This is new to me. Never dealt with this issue before. I’ve asked, described the issue to friends/half-*** mechanic I know, and only get a shrug of the shoulders. I’m sure this issue has been discussed, but I honestly don’t have the time to do a search.
2005 Impala base with the 3.4
turn signals just buzzed when I turn on the switch in either direction. The battery light comes on and I believe the seatbelt warning light comes on too. But when I cancel the turn signals, instrument panel lights go back to normal.
hazard lights work as they should when turned on.
my initial thought was relay. I swapped out every relay in the fuse panel on the left side of the dash. Didn’t fix the issue. So I started pulling fuses. I didn’t swap them, just inspected and they appear fine.
today I put in a new combination switch, still no turn signals. Everything else on the switch worked and still works as it should, just no turn signals…
so please, I beg of you, what am I missing?
Old Jul 12, 2025 | 7:50 PM
Rednucleus's Avatar
Where do you hear the buzzing? Maybe another relay under the dash??
Old Jul 13, 2025 | 8:07 PM
Parks911's Avatar
Thanks for the response. My hearing isn’t that stellar, but last night I did attempt to track the sound down to around the hazard light switch.
after reading other posts and other forums, today I choose to replace the hazard light switch with hopes it would cure the issue.
unfortunately it didn’t. But I now know for a fact that the buzzing is coming from the hazard light switch when attempting to use turn signals.
I did read somewhere about a ground wire behind the divers headlamp housing. I believe this is the one on the radiator support. I won’t have time to dig back into it until next Sunday. I have some wire, soldering iron, heat shrink, and I’m sure I can find an eyelet rather easy. So next Sunday, I’ll cut out the ground and splice a new one in and see if I wasted more time or fixed the issue.
WrenchThrower4
Nov 22, 2021 8:52 AM
danbailey
Feb 23, 2012 2:40 PM
bsr2002
May 22, 2010 3:59 PM
timberland73
Dec 16, 2009 11:04 PM
Manor_Mullet
Apr 28, 2008 2:13 PM
