Need some help!
There is no real way to tell. The VIN number doesn't give all that info. If you have a clutch pedal and no PRNDL in the dash then you did not have an automatic. Check the fenders for an emblem that might a V which would mean it had a V8. If it has dual exhaust then it had a large V8. This all applies if someone did not make changes in the past.
The problem is that it is a clutchpedal and a automatic shifter and its welded shut a hole in the floor.
The emblems on the fenders are 396 turbojet but I dont know if they are original.
Ryan Brickel
May 25th, 2012 4:06 PM
sandlercd_22
January 5th, 2008 9:33 PM
Jasons1990lumina
February 23rd, 2006 1:26 PM
