2014 Chevrolet Impala
Includes: Bel-air
Platform: B-body & W-body
No crank 2006 impala
Old Sep 12, 2016 | 1:46 PM
rjrick's Avatar
Default No crank 2006 impala
New battery & starter, same problem, starter clicks once, all pos $ neg connection appear clean and tight.indicator lights on dash do NOT light, after several attempts they light and I hear 1click in crank position. I also hear a clicking it middle of the dash this comes and goes, I'm suspecting a faulty ignition switch and or pass lock. Any suggestions would be greatly appreciated.
Old Sep 13, 2016 | 11:22 AM
Frank3's Avatar
Welcome to the forum. Has any other work been done on the car? I've seen bad grounds cause some really strange problems.
Old Sep 13, 2016 | 2:37 PM
kevinkpk's Avatar
I'd go with that based on the dash light issue.
Old Sep 15, 2016 | 12:29 PM
rjrick's Avatar
Default No start
Thanks for the suggestion, I've seen that too. I found the blend door actuators behind the glove box to be the cause. They continue to run draining the battery, I suspect that heater control is faulty. After fully charging the new battery, performing pass lock reset and unplugging the actuators the car is running now.
