2014 Chevrolet Impala
Includes: Bel-air
Platform: B-body & W-body
No electrical power to entire car
Old Jan 24, 2014 | 6:09 PM
rdc's Avatar
rdc
Unhappy No electrical power to entire car
2002 Impala
Turned off engine for a couple of minutes. When attempted to restart car nothing happened. No power to anything. Is there a "master fuse"?
Old Jan 24, 2014 | 6:15 PM
Welcome to the forum...
Its possible you have a mega-fuse located in the positive battery cable path to the fuse box, however I would verify that your battery is good, it can read 12 volts and still be bad.
Also check the battery cables then need to be clean and solidly connected...
I would be willing to bet your battery is shot....
Old Jan 24, 2014 | 6:36 PM
rdc's Avatar
rdc
New battery. Car had no starting problems until today. Even yesterday at 15 degrees.
Old Jan 25, 2014 | 3:17 PM
blue-impala's Avatar
Check the connection of both ends of the battery cables, especially the negative where it is attached to the engine block (Ground) This happened on my 01 Impala once. It was corroded and a bit loose.
Old Feb 2, 2014 | 10:17 AM
eugene_leduc's Avatar
It could be blown fuse.
skidooxps
Jun 7, 2014 9:22 PM
ericconn
Apr 10, 2012 11:41 AM
idxair
Corvette
Mar 22, 2011 11:23 AM
viruz_one
Feb 25, 2010 10:49 PM
