Passlock problems
Passlock problems
<TABLE border=0 cellSpacing=0 cellPadding=3 width="100%"><TBODY><TR><TD class=row1 height=28 vAlign=top>Security light started coming on month ago and progressively got worse each week. Tried electric contact cleaner but no luck. Replaced ingnition lock cylinder, checked passlock connection and wires behind dash. All good. Did security relearn. Reprogrammed remote start. Sarted. Got 15 minutes down the road and light came on
Where does the passlock ground out to? Anyone have a diagram?
Can i test this other things before looking at the BCM?</TD><!-- End replacement - Bottom aligned signature MOD --></TR><TR><TD class=row1 vAlign=bottom>
</TD></TR></TBODY></TABLE>
Well tonight i was driving home and the security turn on. turned off for a bit. then started flashing. Thing is it would do it 6 times, then 4 times then 5 times, then twice.
Passlock -How did you bypass?
Seems to be a common view that the passlock system is crap, I just realized my starting/running issues are most likely caused by the passlock and having lost the factory (smart) key, and using a copy for the past few weeks.
So, how did you bypass (disable?) the passlock system? Details please!
-Clay
sbkmike
September 24th, 2017 11:03 PM
