2014 Chevrolet Impala
Includes: Bel-air
Platform: B-body & W-body
popped up on my 2008 chevy impala
Old Nov 15, 2017 | 6:47 AM
smaerdym's Avatar
Default popped up on my 2008 chevy impala
the display says "Engine Power Reduced" and then switches to "Service Traction Control"
Old Nov 15, 2017 | 8:28 AM
you have an issue with the drive by wire throttle system. post the codes
Old Aug 12, 2018 | 5:38 PM
smaerdym's Avatar
P2138 - states to replace the Accelerator Pedal
Old Aug 12, 2018 | 10:54 PM
nope. If only it was that easy. the code is for a fault is in the sensor 1 circuit. the pedal, wiring or pcm could be the fault. testing is required to determine where the fault lies. if you want to guess, you could replace the pedal.
