2014 Chevrolet Impala
Includes: Bel-air
Platform: B-body & W-body
rear defrost
Old October 31st, 2007 | 7:36 PM
jay's Avatar
jay
Default rear defrost
hi this is my first post i hope you guys could help me here
when the radio is on ...and when i try to switch the rear defrost on (for rear windows) i lose my radio ....any idea? i have 2002 impala thank you all
Old November 6th, 2007 | 7:09 AM
66ImpSS396's Avatar
Default RE: rear defrost
Check the grounds for the radio.
66ImpSS396
Old November 6th, 2007 | 1:14 PM
rbarrios's Avatar
do those year impalas have an external antenna- or is the antenna built into the rear window.
the 2006/2007 impalas have the defrost grid- and radio antenna on the back window.
ive heard of people getting tint (metallic tint) and the radio reception going bad.
maybe you have tint and the defroster and antenna are making contact thanks to the tint?
Old February 18th, 2017 | 2:39 PM
Dennis Vogstrom's Avatar
I know I'm a few years behind on this post. You probably have it repaired by now, but if anybody else should find it such as I did, there is a module on the rear window very top, not in the Middle with a grit is it's at the top on the driver side, left side of the window. First, you have to remove the C pillar plastic molding to get to the electrical connector. There should be a white and a green wire in the connection.
The white has power all the time with the radio, the green one switches with a defrost. It goes to the module and then to the rear window and the antenna if that module is bad you'll get this issue.
​​​​​​ There is a gray cable for the antenna the sleeve pulls back to disconnect from the module, that is screwed onto the lower portion of the C pillar by the rear window.
ncfr2544
January 2nd, 2022 10:33 AM
coling659
October 14th, 2013 10:17 PM
thenaes
December 2nd, 2011 8:59 AM
313hitman
February 16th, 2007 8:51 PM
powell601
January 17th, 2007 12:34 AM
Quick Reply: rear defrost
