2014 Chevrolet Impala
Includes: Bel-air
Platform: B-body & W-body
rear defrost
Old Oct 31, 2007 | 6:36 PM
jay's Avatar
jay
Default rear defrost
hi this is my first post i hope you guys could help me here
when the radio is on ...and when i try to switch the rear defrost on (for rear windows) i lose my radio ....any idea? i have 2002 impala thank you all
Old Nov 6, 2007 | 6:09 AM
66ImpSS396's Avatar
Default RE: rear defrost
Check the grounds for the radio.
66ImpSS396
Old Nov 6, 2007 | 12:14 PM
rbarrios's Avatar
do those year impalas have an external antenna- or is the antenna built into the rear window.
the 2006/2007 impalas have the defrost grid- and radio antenna on the back window.
ive heard of people getting tint (metallic tint) and the radio reception going bad.
maybe you have tint and the defroster and antenna are making contact thanks to the tint?
Old Feb 18, 2017 | 1:39 PM
Dennis Vogstrom's Avatar
I know I'm a few years behind on this post. You probably have it repaired by now, but if anybody else should find it such as I did, there is a module on the rear window very top, not in the Middle with a grit is it's at the top on the driver side, left side of the window. First, you have to remove the C pillar plastic molding to get to the electrical connector. There should be a white and a green wire in the connection.
The white has power all the time with the radio, the green one switches with a defrost. It goes to the module and then to the rear window and the antenna if that module is bad you'll get this issue.
​​​​​​ There is a gray cable for the antenna the sleeve pulls back to disconnect from the module, that is screwed onto the lower portion of the C pillar by the rear window.
ncfr2544
Jan 2, 2022 9:33 AM
coling659
Oct 14, 2013 9:17 PM
thenaes
Dec 2, 2011 7:59 AM
313hitman
Feb 16, 2007 7:51 PM
powell601
Jan 16, 2007 11:34 PM
