2014 Chevrolet Impala
Includes: Bel-air
Platform: B-body & W-body
Replacing the upper & lower intake gasket on a 2000 Impala 3.8
Old Oct 12, 2011 | 8:48 PM
gnx547's Avatar
Default Replacing the upper & lower intake gasket on a 2000 Impala 3.8
My friend has a 2000 Impala 3.8 with 199,000 miles on it. The upper & lower intake and valve cover gaskets are leaking. I will buy the Fel pro upper and lower intake gasket kit. Does the factory GM 3.8 upper intake have problems or defects from the factory? I know Dorman sells the upper intake, should I also replace the upper intake? Or is the factory one good?
I know this job will take a few hours to do, besides the gasket kits, Is there anything else I should replace while doing this job? Is there also a write up for doing this with torque specs on this forum?
Thanks!
Old Oct 12, 2011 | 9:08 PM
MDTAHOE's Avatar
Professional Mechanic
Yes there is a problem with the factory upper intake. If it is leaking coolant it needs to be replaced. Use the Dorman it fixes the problem
kalex0353
Dec 6, 2015 7:15 AM
hna2195
Apr 20, 2015 8:06 PM
bills 98 wt1500
Dec 29, 2011 11:47 PM
gulfcoastjoe
May 4, 2008 12:38 PM
