Seat heater
Seat heater
I have a 2003 Chevy Impala and the drivers seat heat stopped working. It is getting close to winter and I have to get this working. Can anyone tell me where to start? I am handy but dont know much about cars. Thanks
My grandma's 04 has the same issue. First check the fuses to see if the circuit is getting power. If the fuses are good then you will have to use a tester to see if the switch has power and if the switch is working.
I tested the fuses and they were good but haven't had the time to check the switch. If the switch is working properly and has power than I would assume the heating elements are bad and have to take the seat apart to get to, not a fun job.
