sister's impala spitting at me
My sis has a '02 impala 3.8l.. This evenig it started steaming under the hood, Well being the good big bro' that I am, Iwent to check it out. I saw coolant on the right side of the engine, but couldn't find where it's coming.After about a hour of searching I found it Under the alternator running through the tensioner, a little black hose. All I want to know is what kind hose is it and how hard is it to replace.
RE: sister's impala steaming
Is it coming from the hose? or from the pipe that the hose attaches to? A lot of these engines have the pipe corrode and break off. They are plastic from the factory and there is a steel replacement available for it. If it snaps off flush with the intake, then it can be a bugger to get it out. You have to use an easy-out to try and remove the broken piece. If it is cooperating, you can get it without removing the intake, but most times you end up pulling the intake off to fix it properly.
Yep, they were wrong. The dealer was trying sell me both pipes for $15.00, went to a local parts store and got both @ $2.37. If you're ever in the triangle area look for ( WALKER AUTO PARTS ). It's found in help section, heater hose fitting #47065.
suburbansr4me
December 15th, 2014 7:16 AM
little jimmy 1990
May 29th, 2012 12:40 PM
