2014 Chevrolet Impala
Includes: Bel-air
Platform: B-body & W-body
spark plug wire confusion
Old Jun 16, 2012 | 4:57 PM
  #11
03SSLE's Avatar
An '85 Chevy 5.0 would have a clockwise distributor rotation. It would have to be an Olds or Pontiac engine to be counterclockwise.
To verify the distributor is installed properly disconnect power from it and pull #1 plug. Put your thumb over the plug hole and have a friend tap the engine over until you feel compression. Continue to turn the engine over by hand until you are at TDC. Pull the distibutor cap and observe where the rotor is pointing. It should be pointing at the #1 tower on the cap as shown in the diagram below. Make sure the wire on that tower is going to #1 cylinder. Check to make sure all other wires follow in the correct order moving clockwise around the cap. Put the cap back on, the plug back in, connect power to the distributor and the engine should fire.
Old Jun 16, 2012 | 5:17 PM
  #12
kevinkpk's Avatar
Thats a good point, I also post if it is an sbc, I know a little about Olds. If you are hving to determine #1 cylinder is at tdc by yourself, Put a wadded tissue in the plug hole. When it pops out, stop cranking as it is close enough to then set the distributor.
Old Jun 16, 2012 | 5:40 PM
  #13
clintsy's Avatar
I got it!
The cap was off by a lot
and a couple wires got mixed up
Thanks, that diagram helped
Old Jun 16, 2012 | 7:01 PM
  #14
03SSLE's Avatar
Good deal...Glad to hear you got it figured out and it's running like it should.
Old Jun 16, 2012 | 10:06 PM
  #15
kim's Avatar
kim
Ok try this take #1 plug out turn it over untill it blows your finger out, then line up marks on balancer an timming tab, pull cap an make sure #1 is where #1 wire is if it is make sure firering order is clock wise . Good luck.
mamulan
Aug 20, 2014 8:39 AM
TPM
May 14, 2013 5:58 PM
Simplejack
Feb 7, 2012 7:28 PM
PastorK
Mar 6, 2010 6:55 PM
braggent
Jun 19, 2006 12:25 PM
