2014 Chevrolet Impala
Includes: Bel-air
Platform: B-body & W-body
TPMS Reset
Old Aug 1, 2016 | 11:36 PM
scatgo's Avatar
Default TPMS Reset
Have a 2011 with a 3.9 and I keep getting a service TPMS warning on my dash. I know something is not right with my front right tire because I get a - symbol insted of the tire pressure. Iam not sure how to deal with this because I found only one video that shows you how to go through the menu on the dash but its not good for a 2011. Any info on how to get this right would be great.
Thanks
Old Aug 2, 2016 | 8:21 AM
cleveland63b's Avatar
probably has a bad sensor, make sure all the pressures are good and you can attempt a relearn
Old Aug 2, 2016 | 2:05 PM
scatgo's Avatar
how do you do a relearn? When I push the buttons to the right of the speedo I cant find anything about resetting the tpms?
Old Aug 3, 2016 | 7:10 AM
scatgo's Avatar
So anyway I just orderd a new sensor for the front left wheel. I am going to have them install it when I get a alighment. Any info on how to get things working right once the new sensor is in would be great.
Thanks
Old Dec 20, 2016 | 7:45 AM
Jakespeed63's Avatar
We have a whole fleet of these Impalas. You need to use the key fob in addition to a TPMS tool to reset system.
(press both lock and unlock fob buttons, until horn beeps)
You can also put it in the relearn mode(with key fob) then let air out of each tire until horn beeps. Starting with Lf and working way around vehicle (LF, RF, RR, LR) After deflating LR, horn will beep twice. System now reset. Proceed to inflate all tires back to factory spec.
Old Feb 9, 2017 | 1:51 PM
Doug Pitts's Avatar
Default TPMS tool
what is and where do I find a TPMS tool?
