K5 Blazer 1969-1994
Platform: Truck, GMT 400
1988 c1500 no start till you spray throttle
Old May 12, 2015 | 2:33 PM
TLW64's Avatar
Default 1988 c1500 no start till you spray throttle
Working on a 1988 c1500 chevy pickup with a 5.7 liter engine . Engine will not start untill you spray carb cleaner into throttle body , after you spray the engine will start and will run fine untill you turn engine off. No injector pulse at crankover untill it has been sprayed. Have already replaced distributor with new distributor still Have same problem .tried another computer on vehicle and still had same problem. The two grounds that supply injector pulse from the ecm are present untill you go into crank position. Throttle position sensor is reading correctly. Any help would be greatly appreciated.
next2nothin
Jun 24, 2011 8:56 PM
hwfan
Sep 27, 2010 2:00 AM
spenny
Jun 16, 2009 9:10 PM
Gaidin43
Jun 2, 2009 5:33 PM
gmag69
Jul 7, 2008 3:54 PM
