K5 Blazer 1969-1994
Platform: Truck, GMT 400
1989 Chevy 350 floods after warming up
Old May 20, 2011 | 9:59 PM
Zuby's Avatar
Default 1989 Chevy 350 floods after warming up
1989 Chevy 350 tbi in k1500 truck. When cold starts and runs fine, but after it has warmed up it suddenly starts to dump fuel and floods out. Once in a while holding accelerator to floor and starting will actually get it to start, but usually have to wait until it cools down and then it starts again. Replaced the gasket under throttle body, because it was leaking, changed plugs, cleaned rotor and distributor cap, check EGR valve, IAC valve, changed coil. I'm stumped. Once in a while the check engine light comes on, but does not stay on. have not hooked to computer yet, because can't depend on it to make it into town to the parts store to check it. Anyone got any thoughts?
Old Jun 18, 2011 | 10:01 PM
btodd88's Avatar
Sorry I don't have the answers you need, but I need the same answers. I have what sounds to be the same problem. It will crank up and run fine for about 5 min. then the drivers side injector starts dumping fuel and filling up the bowl while at idle. when you touch the gas in floods and stalls. I still have not found what is causing the injector to do that, but there's got to be something telling it to spray fuel like that. I'm hoping some type of sensor. Somebody has to know what's causing this
and hopefully we can get some helpfull info, cause i'm not going to start replacing
stuff just guessing. Anyways, good luck and i feel your pain.
Old Jun 19, 2011 | 2:15 PM
Zuby's Avatar
Default Answer to flooding
Turns out it was the choke sensor. located near where the radiator hose goes into the manifold there is a sensor screwed into the manifold. Mine was broken. $20 part and it runs like a champ. Hope yours is the same problem, because it was an easy fix.
AgentM
Aug 2, 2015 7:47 PM
SaturnMan
Uplander
Mar 13, 2015 7:02 PM
KDaniel
Nov 26, 2013 4:35 PM
dgjohns
K5 Blazer
Aug 27, 2011 8:37 PM
trevorwright
Jan 7, 2010 1:34 AM
