K5 Blazer 1969-1994
Platform: Truck, GMT 400
83 K5
Old Jan 23, 2008 | 11:40 PM
83k5devil's Avatar
Default 83 K5
I have an 83 k5 silverado and i was wondering what is the largest tires I can put on with out cutting into the wheel well. also with a 10 bolt or a 12 bolt rear.
Old Jan 27, 2008 | 3:31 PM
k5goose's Avatar
Default RE: 83 K5
Depends on what you are using the k5 for. Street only, or offroad. I first had a 77 with 35 bfg mts with no lift. They would rub the fenders a bit offroad but I didnt care. A safe all around tire might be 33 bfg ats. Post up a lil more info on what you use the k5 for.
Goose
Old Jan 30, 2008 | 9:08 AM
YotisSpunkmeister's Avatar
Default RE: 83 K5
it also depends on the size lift you have, if you have one. the newer model K5's have smaller wheel wells, not allowing the oversized tires without a lift. stock k5's came with 33's if they were the 4x4 cheyenne edition.
